1998 Infiniti I30 Brakes
170,000 MILES • 6 CYL • 2WD • AUTOMATIC
JJSOS
any idea how to remove back brake rotors?
Is a puller required & if so any special technique to re- installing? ANYTHING UNUSAUL ABOUT REPLACING BRAKES WITH THIS MODEL? Thank you
Jul 28, 2010 at 9:12 AM
KHLOW2008
  • 41,812 POSTS
Hi jjsos,
Nothing special about removing the rear rotors. After the brake calipers are removed, the rotor would come off, though it might stick, some banging with a mallet should work.
Aug 1, 2010 at 10:12 PM
