1997 Infiniti I30 Replace Spark Plugs
1997 INFINITI I30
115,500 MILES • 6 CYL • FWD • AUTOMATIC
PDB
Vehicle has a coil based spark plug system. What steps need to be taken to remove the coil so the spark plugs can be replaced.
I know how to reach the coil covering the plugs.
Oct 29, 2010 at 12:58 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Remove the 4 allenhead bolts from the v-6 3000 emblem in center of the valve cover. Lift off { Tshaped v-6} 3000 emblem. Remove spark coils located beneath. Remove plugs under spark coils. As far as I know you must replace coils and wires together. However you can replace just the plugs.
Oct 29, 2010 at 3:44 PM
PDB
As a follow up to replacing the sparks plugs on my 97 Infiniti I 30, do the coils simply lift off or is there a special technique to remove the coils to get to the plugs?
Oct 29, 2010 at 6:39 PM
BLUELIGHTNIN6
  • 16,542 POSTS
once cover is removed you should be able to see the coils mounting bolts
Oct 29, 2010 at 6:43 PM
