1997 Infiniti I30 FUEL PUMP
12,000 MILES • 6 CYL • 2WD • AUTOMATIC
SIERRAA
HOW DO I CHANGE THE FUEL PUMP MYSELF?
Feb 11, 2008 at 6:23 PM
2CARPRO JACK
  • 11,533 POSTS
You scored ! remove the lower portion of the rear seat and there is an inspection cover to give access to the tank unit.Most cars the fuel tank has to be taken out of the car. Before you remove the fuel lines, release the pressure at the schrader valve (like on a tire) on the fuel rail. I strongly suggest you use an OEM (Nissan) pump
Feb 12, 2008 at 12:06 AM
