1997 Infiniti I30 Final Oil Changing
1997 INFINITI I30
167,000 MILES • 6 CYL • FWD • MANUAL
C109RT
How do I drain and refill the final drive oil?
Where do I ADD?
Jul 1, 2009 at 2:26 AM
KHLOW2008
  • 41,814 POSTS
Hi C109RT, Thank you for the donation. The trans and differential gear oil are in the same assy and the drain plug is Item # 3. Filler plug is on side of trans, Item # 15 in the diagram. You need a pump or tube to fill up to lower mark of filler plg, ie fill till it flows out of filler plug.
https://images.2carpros.com/forum/automotive_pictures/192750_Transaxle97InfinityI30_1.jpg
Jul 1, 2009 at 6:00 AM
