My car overheated the other day and then I noticed that only 1 of the radiator fans turned. I thought that it might be a fuse but they appeared mto be OKI (30A fuses) So I switched the fuses to see if this would switch the fans that would turn on. Now both fans did not move. So I switched the fuses back and still both of tghe fans do not move. What did I do? Did I do break my 2nd fan? I wonder if switching the fuses made things worse and what I should do. Please help as this is our only car rightnow and with both fans broken I am afraid to drive it anywhere.
Thank you
Thank you
Mar 3, 2010 at 7:59 AM
