How to replace pulley, what size is the bolt taht holds it on, and can it be done from undeneath car
Jul 31, 2010 at 3:07 AM
KHLOW2008
✓Experienced Mechanic
Hi tfore4@hotmail.com,
Disconnet all belts.
Remove the pulley central bolt, you need an impact wrench or appropriate holding tools for the pullwy.
It should be done from under the vehicle.
The bolt size should be a 24 mm but different engine varies, from 19 to 27mm.
Aug 1, 2010 at 10:03 PM
