2006 Infiniti G35 Missing
42,000 MILES • 6 CYL • 2WD • AUTOMATIC
KLUGENFELTER
On occasion, especially around 6 to 7pm my car will begin to miss for no apparent reason. Most of the time it runs fine, but when it does miss, this can continue for about 30 minutes and then the car goes back to idling as normal. This one is really baffling to me. Any ideas?
Aug 8, 2008 at 12:34 PM
MERLIN2021
  • 17,250 POSTS
Check engine light on yet? If so have the codes read...did the car have something else to do between 6-7pm? LOL
This is the only tech bulliten on yourr electrical system, may be related?
MIL "ON" WITH DTC U1000 OR U1010 STORED IN ENGINE CONTROL UNIT TECHNICAL SERVICE BULLETIN Reference Number(s): ITB06-004a, Date of Issue:  March 31, 2006 Related Ref Number(s): ITB06-004, ITB06-004A ARTICLE BEGINNING IF YOU CONFIRM The MIL is "ON" with  DTC U1000 (CAN COMM CIRCUIT) OR  DTC U1010 (CAN COMM) [2006 Models only] stored in the engine control unit, and There are no drivability incidents. DETERMINE IF This bulletin applies by performing steps 1 and 2 of the Service Procedure. ACTIONS If this bulletin applies, there may be excess resistance in certain ground connections:  Clean/re-tighten ECM ground connections.  Clean/re-tighten negative battery cable body connection and battery post connection.  If needed, clean and ensure good contact between the steering member assembly and the left INFINITI: 2002-2004 I35; 2002-2006 Q45; 2004-2006 QX56; 2003-2006 FX; 2003-2006 G35; 2003-2004 M45; 2006 M CLASSIFICATION: EC06-002a APPLIED VEHICLES: 2002-2004 I35 (CA33); 2002-2006 Q45 (F50); 2004-2006 QX56 (JA60); 2003-2006 FX (S50); 2003-2006 G35 (V35); 2003-2004 M45 (Y34); 2006 M (Y50) NOTE: This bulletin has been amended. The Applied Vehicles, IF YOU CONFIRM and Claims Information sections have been changed. No other content has been changed. Discard all previous versions of this bulletin. Page 1 of 4 MIL "ON" WITH DTC U1000 OR U1010 STORED IN ENGINE CONTROL UNIT -20... 8/9/2008 http://www.ondemand5.com/mric/common/asp/printart.aspx
Aug 8, 2008 at 11:24 PM
