engine overheating?
52,000 MILES • 6 CYL • AWD • AUTOMATIC
TONYMAKALINAW
As I'm driving, the temperature gauge on my 2005 Infiniti G35 just started to rise and fall from normal to near the top of the gauge, triggering the cooling fans. It doesn't appear to be overheating but it never did this before. Coolant level is correct, serpentine belt is fine, and the water pump is not making any noise.
Bad coolant temp sensor? thermostat? any ideas?
Oct 7, 2009 at 10:05 AM
IMPALASS
  • 3,112 POSTS
It sounds like the coolant temperature sensor needs to be replaced. Here are two guides to go through and the location of the sensor below.
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
and
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Oct 7, 2009 at 2:13 PM
TONYMAKALINAW
I went to Autozone, there are no codes displayed, everything seems to be okay. After driving for a while, with the engine hot, I checked under the hood, and noted the following: the coolant in the reservoir is at the proper level, but cold. The upper radiator hose is hot, but the lower one is cold. Very little heat coming out of the vents with the heat turned all the way up. The temp gauge spikes up close to the top but the car doesn't seem to be overheating. The gauge fluctuates up and down from center to top slowly but frequently.
Any ideas?
thanks
Oct 8, 2009 at 8:09 AM
IMPALASS
  • 3,112 POSTS
It sounds like the water pump or thermostat needs to be replaced. Here are two guides to help walk you through the process.
and
https://www.2carpros.com/articles/water-pump-replacement
Let me know
Oct 8, 2009 at 3:38 PM
TONYMAKALINAW
I checked everything... it was none of the above...Took it to a mechanic, he simply purged the air out of the cooling system and everything is fine.
Oct 9, 2009 at 8:40 AM
IMPALASS
  • 3,112 POSTS
Hello –
That is great to hear, air getting trapped does make the engine act funny. Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Cheers
Oct 9, 2009 at 9:51 AM
DWIGHTMAN
On warm days (usually over eighty degrees) my engine will begin to overheat when I am sitting in traffic. If I turn off the A/C the temperature will stabilize and I can keep within the operating range but it is on the high end of the scale. If I turn the A/C back on the temperature will begin to rise. I do not notice this as much on the open highway but if the outside temperature is up over ninety degrees, the engine temperature will push up to the high side of the scale even in highway driving. Turning off the A/C is the only way to keep within the operating range. When I am sitting in traffic at a red light, I can here the fans kick on so I am pretty sure the fans are operating when called for. I have had the coolant checked at Infiniti dealer and they are telling me it checks okay. Would the thermostat be the problem?
Nov 1, 2018 at 11:32 AM (Merged)
KHLOW2008
  • 41,812 POSTS
Hi dwightman,
Thank you for the donation.
There are a few possible causes for the problem :
1. Cooling fan. The cooling fan operates at different speed for cooling and if it is not working at the highest speed when the temperature is high, the efficiency is insufficient. However this would not be a likely cause as at cruising speed the moving air should be able to cool the radiator to lower the temperature reading.
2. Radiator partially clogged. If the radiator is clooged partially, cooling efficiency would be reduced causing high temperature reading. When this occurs, the higher the speed the higher would the be temperature reading.
3. Bad thermostat. It could be stuck in partially open position resulting in reduced coolant movement that would cause the temperature to rise.
4. Insufficient coolant. When engine is cold, remove the radiator cap and check if the coolant level is at the neck. Check the reserve tank coolant level.
5. Bad water pump. This would reduce the coolant flow efficiancy.
From the above, item 2 and 3 would be the most probable cause.
MRTWELVEVOLTS
Did you ever fix it? I am having the same exact problem?
Thanks
ELIOTT PUGA
I have the same problem with my Infiniti. It gets overheating went I turn the A/C on. Why?
ROL*S.
  • 61 POSTS
Hi Eliott,
Were radiator cooling fans running when A/C was turned on? If so, did you notice temperature getting hot while on the freeway or on the streets. Also, A/C temperature was nice and cold the whole time?
EMJO
My car started intermittently overheating. On three occassions now, the temperature gauge has gone up to within a few tick marks of the first heavy hot line. (half way from center, to almost touching).
I do not see exhaust in the coolent resorvoir
I do not see white smoke from the tail pipe
Keeping the car in motion keeps it cool where it is supposed to be.
When the temp gauge goes up, the AC blows warm air
When I see the gauge go up, I turn off the car for a few moments, then the next time I start it, it is working fine.
This occurs when the outside temperature gauge in the car reads 92 or hotter.
When engine temperature gauge is showing the correct temperature, the AC is cooling great and the AC fans are blowing hard
When the engine temperature gauge is showing hot, and the AC is blowing warm or hot air, then the AC fans are running slower.
There is no apparent loss of coolant
I do notice an extremely faint smell sometimes of hot coolant, but it is so faint, I am not sure of it. I do not see any measurable loss from the coolant resorvoir or any leak marks on the engine or in the exhaust.
Special note: my ac is on automatic because the control panel is damaged and needs to be replaced. As a consequence the control buttons do not work. (they want 2900 dollars to replace that control panel)
DOCFIXIT
  • 18,828 POSTS
Hi
Open hood engine running A/C on do cooling fans come on? when car heats up confirm fan operation.
Let me know
Thanks for donate
EMJO
Thanks for getting back to me so quickly. I assume by cooling fan you mean the fan in front of the radiator. Is that correct?
DOCFIXIT
  • 18,828 POSTS
That is correct suspect intermittent operation causing heat up
EMJO
Ok, thanks for clarifying that.
I will watch it over the next couple of days. It may take a day or two before it heats up again. I will watch it while he air is working, and then when it heats up again, take a peek and give you the results.
i appreciate your patience.
CARMAN8212
It overheats head gasket not cracked
have a leak down test performed to verify head gaskets.
how long did you drive it overheated??
CARMAN8212
Not long I check the oil no sign of head gasket blown
that is not always a good indicator. you need the leak down test.
CARMAN8212
Havent drove it over heated just enough to know it gonna over heat
I park it home soon as...I bleed the radiator and it started up but didnt take long for it to start over heating also I only filled to the with water to bleed air
CARMAN8212
Had the problem before with air being trapped just dont rmr how to release air out of the lines near heater core
air will bleed itself over time. you still need that leak down test
DAVID INMON
I have replaced water pump and thermostat it over heats when I turn on the air conditioner within five minutes of turning on air conditioner.
HMAC300
  • 48,601 POSTS
check cooling fan fuses and relays under hood the one for air conditioner may not be kicking on then have it checked for a head gasket problem.
