2005 Infiniti G35 Battery
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
HAILIED12
I HAVE A 2005 INFINITI G35 SEDAN WITH 75K MY BATTERY EVERY NIGHT IS BEING DRAIN I CHECK THE ALTERNATOR ITS PERFECT I CHANGE THE BATTERY AND THAT WASNT IT I MAKE SURE EVERYTHING IS TURN OFF AT NIGHT I DONT KNOW WHY MY CAR IS DEAD IN THE MORNING EVERY NIGHT IS IT A FUSE THAT IS DEAD OR SOMETHING ELECTRICAL WHAT SHOULD I DO
Mar 30, 2009 at 2:17 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Inspect your battery cables to ensure they are tightened properly and cleaned at both ends of connection. More information about this common issue can be found at our Car Repair Troubleshooting page, linked below..
https://www.2carpros.com/first_things/why_is_my_car_battery_dead_over_night.htm
Thanks for using 2CarPros.com!
Mar 30, 2009 at 2:24 PM
HAILIED12
I DID I THOUGHT IT WAS THE BATTERY I HAD A OPTIMA FOR TWO YEARS N IT WAS PERFECT UNTIL A WEEK OF AGO THAT MY BATTERY DIED SO I BOUGHT A NEW TO SEE IF THAT WAS THE PROBLEM N IT DIED AGAIN IT CHECK THE WIRES I TIGHTEN IT REALLY GOOD ITS NOT THE ALTERNATOR WE TEST IT OUT IT WAS PERFECT IS IT A FUSE OR MY BOSE CD DRAINING IT
Mar 30, 2009 at 2:29 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If you have had the charging system tested to be OK then it would have to be an accessory drawing current overnight when it is not supposed to be. Some examples would be a faulty glove compartment switch keeping the glove box light illuminated at all times. You will need to inspect electrical accessories carefully.
Mar 30, 2009 at 2:31 PM
HAILIED12
THEIR IS A STUPID NOISE COMING FROM THE GLOVE DEPARTMENT ITS MAKING A CLICKING NOISE EVERY 3 SECONDS DONT KNOW WHAT THAT IS EVER SINCE I HAD THE CABIN FILTER CHANGE ITS BEEN MAKING THAT NOISE N A WEEK LATER THE BATTERY HAS BEEN DYING ALSO THAT WEEK I HAD MY BELTS N SPARKS PLUG CHANGE BUT THAT COULDNT BE IT
Mar 30, 2009 at 2:36 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Okay, I believe you have found the problem. The clicking noise is a faulty relay. You will need to find which relay is clicking and replace it.
Mar 30, 2009 at 2:38 PM
HAILIED12
HEY THANX I THINK THAT MIGHT BE IT I WAS GOING TO TAKE IT TO A MECHANIC IN THE MORNING BUT I THINK THAT MIGHT BE IT THANX BRO I WILL KEEP U AROUND FOR ANY QUESTIONS LATER ON THANX
Mar 30, 2009 at 2:41 PM
