2004 Infiniti G35 driver window
67,000 MILES • 6 CYL • 2WD • AUTOMATIC
PAT750
the window on the driver's side does not respond. It will not go upor down. What do you think the problem is. I've checked the fuse panels and see nothing about window fuses. Can you help me
Jul 26, 2008 at 4:18 AM
THEJONESHOME
Pat750, did you resolve the windo problem? We're having a problem with our driver's side window as well.
Thanks!
Oct 16, 2008 at 1:47 AM
MIKE WARREN
  • 5 POSTS
same think on the 05 G
Dec 10, 2010 at 1:12 PM
THEJONESHOME
The motor for the window that is inside of the door panel had to be replaced. Now the passenger window needs to be done!
Dec 11, 2010 at 3:45 AM
