2004 Infiniti G35 Car is misfiring, computer is not throwin
2004 INFINITI G35
49,000 MILES • 6 CYL • 2WD • MANUAL
DAMNGAMBS
I recently noticed my car was misfiring every once in a while. I removed the plugs, found a bad plug and replaced all of them. While changing the plugs I noticed oil in #5. I had the dealership change the valve cover. The car was still misfiring so I replaced the ignition coil on #5. It's still misfiring and I had a compression check done and everything looks good there. It's getting a lot worse now and I'm not sure what to do now...
Feb 3, 2010 at 9:49 AM
TOOOMANYTOYS
  • 513 POSTS
Check the fuel injector on that cylinder. Use a noid light to see if you have an input signal. You may need to clean injectors or even swap injectors to see if miss travels to another cylinder
Feb 3, 2010 at 10:00 AM
