2004 Infiniti G35
2004 INFINITI G35
39,620 MILES • 6 CYL • 2WD • AUTOMATIC
AL LIPS
I was told that my car needed brake pads on the front. In addition I needed to replace the Rotors because they could not turn them. Question: Does Infinity install what I call a wear bar. This is a warning device that is installed to warn you when your pads are about to do damage.
Feb 10, 2008 at 7:19 AM
AL LIPS
[quote:54f29ec93e="Al Lips"]Brakes problem
2004 Infiniti G35 6 cyl Two Wheel Drive Automatic 39620 miles
I was told that my car needed brake pads on the front. In addition I needed to replace the Rotors because they could not turn them. Question: Does Infinity install what I call a wear bar. This is a warning device that is installed to warn you when your pads are about to do damage.[/quote:54f29ec93e]
Feb 10, 2008 at 7:31 AM
MERLIN2021
  • 17,250 POSTS
I would say yes, since it's built by Nissan, and they use them...Get a second opinion if you are suspicious, and ask to see for yourself!
Feb 10, 2008 at 8:26 AM
