2003 Infiniti G35 climate control problem
86,000 MILES • 6 CYL • 2WD • AUTOMATIC
CARGOVANSALESMAN
When the AC is on at 60 degrees it blows ice cold, when you try to adjust to 61 or above it kicks out heat.
Jun 19, 2008 at 8:50 AM
KHLOW2008
  • 41,812 POSTS
Hi cargovansalesman,
Check the AC thermistor, either it is faulty or located too far from the evaporator coil.
Jun 21, 2008 at 8:22 PM
