2002 Infiniti G20 Shifter
2002 INFINITI G20
95,000 MILES • 4 CYL • 2WD • AUTOMATIC
BACKSTAD
Car shifter now sticks in Park. Need to fiddle with it a lot while press both the large and small buttons on the side of the shifter.
There is a little "keyhole" shaped opening near where the shifter goes into the floorbox. Does that do anything? Would WD40 help?
Roger
Jun 27, 2008 at 11:01 AM
MASTERTECHTIM
  • 4,750 POSTS
double check the brake light operation when its acting up, the shift interlock works through the brake light switch, if brake lights dont work it wont shift
Jun 27, 2008 at 11:03 AM
