2001 Infiniti G20 question
2001 INFINITI G20
ADDISALEM
2001 Infiniti G20 4 cyl Two Wheel Drive Automatic 120.00 miles
when drive no speed,but the digonse says EGR VALVE,IDEL CONTROL,&MASFLOW SENSER. I REPAIR ALL THIS BUT THE PROBLEM IS STEL NO SPEED
Aug 30, 2010 at 12:16 PM
Lack of acceleration,chugging,hesitating,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Aug 30, 2010 at 12:21 PM
