HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Infiniti
G20
Engine
Symptoms
Lean
2000 Infiniti G20 CODE PO171 (SYSTEM TOO LEAN BANK ONE)
MALDANA
MEMBER
2000 INFINITI G20
4 CYL
FWD
AUTOMATIC
12,000 MILES
CODE READS "SYSTEM TOO LEAN BANK ONE"
ANY THOUGHTS OF MOST LIKELY CAUSE.
Tuesday, May 25th, 2010 AT 8:41 PM
MECHANIC
Lean fuel condition could be caused by one of the following below:
1. Vacuum leaks
2. EGR and PCV valve.
3. Low fuel pressure.
4. Dirty fuel injectors.
5. Mass Air Flow Sensor.
SPONSORED LINKS
Tuesday, May 25th, 2010 AT 9:17 PM
Please
login
or
register
to post a reply.
Related Engine Lean Content
Loss Of Power 2000 Infiniti G20
While My Vehicle Is In Park Or Neutral It Will Idle At 800 Rpm's And When I Press The Gas Pedal The Vehicle Will Instantly Try To Cut Off If...
Asked by
Robert Ford
1 ANSWER
2000
INFINITI G20
VIDEO
How To Fix an Engine Backfire
Instructional repair video
GUIDE
Lean Exhaust
Common Misconception: When an engine misfires, the cylinder runs lean, not rich, this is because the air to fuel ratio favors air by 14x. Therefore, an engine must be...
2000 Infiniti G20 The Car Does Not Accelerate Quickly
Maybe Someone There Can Help Me. The Problem My Car Is Having Is - When I'm Stopped And Have To Accelerate, It Takes A While For The...
Asked by
mtpatel37
1 ANSWER
2000
INFINITI G20
2000 Infiniti G20 Idling Inconsistency
The Car Had A Tune Up A Few Months Ago With A New A New Air Filter And Spark Plug Wires. Acceleration And Gas Mileage Iare Great. The...
Asked by
philfoster440
1 ANSWER
2000
INFINITI G20
I Bought This Car With No Remote. I Had Trouble With...
I Bought This Car With No Remote. I Had Trouble With The Battery Going Dead And Had To Jump Off For A Few Days. Well The Last Time I Jumped...
Asked by
Anonymous
2000
INFINITI G20
My Car Recently Caught On Fire Under The Hood After...
My Car Recently Caught On Fire Under The Hood After The Spark Plugs And Wiring Was Changed. The Distributor, Distributor Cap, Harnest...
Asked by
Alliykat
2000
INFINITI G20
VIEW MORE
SPONSORED LINKS
Backfire Repair
Intermittent Misfire
Online car repair manuals
