1999 Infiniti G20 Warning light
RIBBON5303
1999 Infiniti G20 V8 Two Wheel Drive 150000 miles
Have brake warning light and battery light on at same time. Any ideas
Apr 19, 2009 at 5:02 AM
EUGENE123
  • 273 POSTS
first check all your fuses, if they all check out then the brake light could be on because the brake fluid may be low, you may have a rotar or hub going bad, calipers may be worn, or shoes may be worn, a wheel cylinder may be leaking. The battery light comes on because the computer is reading that the charge to the battery is not what it should be
Apr 19, 2009 at 6:01 AM
