1999 Infiniti G20 Power windows
98,456 MILES • 4 CYL • FWD • AUTOMATIC
NAPIAUTO
The power windows and power door locks just stop working, none of the go up or down. I checked all the fuses and relays they seem fine. Can you give me some suggestion of what could be the problem.Maybe I missed a relay but only one 30Amp fuse was labeled power windows.
Jan 6, 2009 at 12:59 PM
ZACKMAN
  • 4,202 POSTS
https://images.2carpros.com/forum/automotive_pictures/55316_99g20windows_1.jpg
Fuse Block (Behind Dash, Left Side of Steering) Fuse #8 10A Circuit Breaker 1 Power Window Relay
Jan 7, 2009 at 6:26 PM
NAPIAUTO
Thank that worked
Jan 10, 2009 at 2:14 AM
NAPIAUTO
Now my power steering hose keep slipping off or bursting . I have change the power steering pump and replace all the pressure hoses and it still happen. What can be causeing it to Burst or build all that pressure.
Jan 10, 2009 at 2:20 AM
ZACKMAN
  • 4,202 POSTS
https://images.2carpros.com/forum/automotive_pictures/55316_95sentraps_1.jpg
Perform the hydraulic system check per Factory Service Manual. If you ask me, I suspect your steering gear is defective. As explained, if pressure reaches maximum pressure (you said the hoses keep bursting - too much pressure), gear is damaged.
Jan 10, 2009 at 1:08 PM
