1999 Infiniti G20 Leaks
118,000 MILES • 4 CYL • FWD • AUTOMATIC
WINNIE KIMATA
What is the Oil Sender Unit and why does it leak? Is it very important and how much should I pay to have it fixed without being reaped off.
Nov 12, 2008 at 4:25 AM
ZACKMAN
  • 4,202 POSTS
Locate your oil filter. It should be in the same area, just above the filter. It is important if you want to know how much oil you have in the crankcase, and how much pressure your oil pump is pushing the oil throughout the engine to lubricate and cool off to prevent the engine from overheating.
Over time, leaks do happen. You may able to get off by taking the sending unit out (while doing oil change, so you won't lose any oil), clean it, put new teflon tape, and re-insert the unit, and tighten it. If that doesn't work, get a new unit, should be around $30.
If you were to have someone fix it, it will be one hour labor.
Nov 12, 2008 at 3:51 PM
