1996 Infiniti G20 Speedometer/odometer and tach.
70,400 MILES • 4 CYL • FWD • MANUAL
PETEMILL
Trying to determine the source of two problems, and to determine if they're related.
Tachometer: Random readings, often pegged at 9000. Sometimes moves in relation to engine speed, but shows "0" at idle and only goes as high as 2000 at actual revs of about 3-4000.
Speedometer and Odometer: Occasionally fall to zero; seems to be triggered by hitting a bump, or, more often, when trip odometer is reset. If you manipulate the trip odometer button (e.g., pull on it or put sideways pressure on it, the speedo/odo pop back on.
Questions:
- Would replacing the instrument cluster fix the problem, or is the issue electrical (e.g., faulty speed sensor?)
- When I replace a speedometer, is it possible to keep the original odometer settings -- in other words, can the odometer from the old unit be moved to the new one?
Thanks much.
Aug 19, 2008 at 1:47 AM
SERVICE WRITER
  • 9,123 POSTS
Let's test...best way to answer the questions. Pull the speed sensor out from the transmission.
https://images.2carpros.com/forum/automotive_pictures/30961_ssen_1.jpg
Volt meter should read about .5V when turning the gear quickly. Post your results and if necessary, we can go further.
Aug 19, 2008 at 12:48 PM
