1996 Infiniti G20 Brake lights don't work
1996 INFINITI G20
120,000 MILES • 4 CYL • FWD • MANUAL
EPONA3508
when I stepon the brakes the brake lights won't work. I have changed all the bulbs, and the fuses, tat I know of inside the car. what else could be the problem? and how d I fix it?
All te other light work. I did have to remove the visor over the steering wheel
Apr 22, 2009 at 10:23 AM
  • 31,937 POSTS
Hi there,
Check the brake light switch, check that there is power at the switch and power through the switch when the pedal is pressed.
mark (mhpautos)
Apr 22, 2009 at 10:31 AM
