1996 Infiniti G20 abs
15,000 MILES • 4 CYL • FWD • AUTOMATIC
DIRTCREW58
When i put my head lights on my abs light comes on. I replaced abs motor relay.. still no help. some times theres a clicking sound coming from the gear shifter.If i turn the lights on and off it will click 90 % of the time.If i drive the car with the lights off the abs stayes off.Is there some kind of relay that sits in the gear shifter., if so is it easy to replace and how do i get to it.Or do i need to have a abs test done. thanks
Dec 2, 2009 at 12:54 PM
  • 75,988 POSTS
Hi irtcrew58 and TY for the donation Electrical issue has never been easy thru the internet compared to being with the vehicle-I wiil give it all I got. Sounds like a short circuit exist between the lighting and brake system Did you replace the actuator relay in same location I wantyou to remove the fuse Z and U and tell me what happned to the light. See below
https://images.2carpros.com/forum/automotive_pictures/12900_fuses_12.jpg
Dec 11, 2009 at 7:22 AM
DIRTCREW58
When i looked in the fuse box there was no letters next to the fuses , also all my yellow fuses are 20 amp..I pulled a 10 amp fuse marked meter, the temp gage, heater blower,abs,check engin,seat belt,them lights that come on befor you start the car are out now.I blew something out.All fuses look good.
Dec 12, 2009 at 3:22 AM
DIRTCREW58
i sent you a reply today ..i need to add that the whole instrutment panel is not working ..i pulled the meter fuse and all went dead
Dec 12, 2009 at 6:10 AM
  • 75,988 POSTS
Do you have a repair manual if so find the fusible links and test all of it and then get back with me
Dec 12, 2009 at 7:07 AM
