1995 Infiniti G20 Slight Whining Noise
100,000 MILES • 4 CYL • FWD • AUTOMATIC
SMJ34
I just bought a 1995 Infiniti G20T with 100,000 miles on it. The care runs great but there is a slight whining noise that occurs when I decelerate, especially as I am soming to a stop. Any ideas of what this could be?
Jul 6, 2009 at 4:47 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Most likely a differential gear whine try this place in neutral let car slow down is noise there?
Let me know
Thanks for donate
Jul 9, 2009 at 4:34 AM
SMJ34
No, it does not do it when the car is in nuetral.
Jul 9, 2009 at 3:26 PM
DOCFIXIT
  • 18,828 POSTS
Well that rules out hub bearings so it is most likely differential bearings or worm pinon and ring gears.
Jul 10, 2009 at 5:07 AM
SMJ34
This is what my dad thought it might be as well. Is this something I should fix right away or can it wait a bit?
Thankyou for your help!
Jul 11, 2009 at 2:52 AM
DOCFIXIT
  • 18,828 POSTS
You could drive a long way with slight whine. If not done recently change trans fluid you want to go with something like a Lucas Oil product.
Jul 11, 2009 at 7:34 AM
SMJ34
Thanks again. I will follow your suggestion and replace the trans fluid.
One last question, on avergae, do you know approximately how much it typically costs be to replace the differential bearrings?
Your assistance is much appreciated.
Jul 14, 2009 at 2:40 PM
DOCFIXIT
  • 18,828 POSTS
@$800 to $1000 Hope you can avoid the repair
Jul 15, 2009 at 6:43 AM
