1995 Infiniti G20 Electrical mystery
150,000 MILES • 4 CYL • FWD • AUTOMATIC
DAVID2327
The other day I realized that my alternator was missing the bottom bolt that holds it on, somehow it had vibrated loose. Today I replaced the bolt but in the process unhooked the battery and took out the alternator. I hooked everything back up the way it came off but for some reason now the interior lights, guages, and ac won't come on unless the car's rpm go above 3 thousand rpm. And when I hit the brakes after that the everything electrical tries to shut off. I've also had to be jumped off 3 times since this morning. Could the battery have gone bad and be causing all of this?
Mar 26, 2009 at 2:59 PM
SOUNDOFSHOVELS
I am having the exact same issue. Did you ever fix it? Has anyone else ever experienced this? Can anyone point me in the right direction? I'm going to kill this car.
Oct 21, 2009 at 6:01 AM
