1995 Infiniti G20 Battery
150,000 MILES • 4 CYL • FWD • AUTOMATIC
CHRISTOPHER13
My infiniti started haveing problems with battery going dead. i changed the battery and all was fine for about a month. then battery started dieing again. when i jumped the car off it will run for about 5 mins then die. i changed the ALT. and i still have the same problem. i was told to pull the neg. wire off the battery while it was runing to see if it says runing. if it dies the alt. is bad. but a have a new alt. on it.( and yes if i remove the neg. from the battery it dies). is there something else that could be wrong with the car. o i have cheached all the fuses i could find (even under the hood and inside the car) but none was blown. if u can think of any thing that might be the proble please let me know. thank u
Jun 9, 2008 at 10:18 AM
CHRISTOPHER13
the alt. was bad. but the reason it cont. to have probles was b\c there was a 75 AMP fuse beside the battery that was blow. it was labeled BATTERY. ones i jumped it out my car begain to work again. i have looked at many part stores in serch of this fuse but have not found it. i was told to go to dealer to find such a fuse. thanks for all your help.
Jun 10, 2008 at 12:26 AM
