1994 Infiniti G20 Misses at idle speed
1994 INFINITI G20
208,000 MILES • 4 CYL • FWD • AUTOMATIC
DBAIRAMIAN
at 800 to 1000RPM or idle speed engine misses or shakes, but above 1500RPM the misses or shakes is minimal.
Feb 20, 2010 at 6:45 AM
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
Feb 20, 2010 at 7:53 AM
