1994 Infiniti G20 air cond compressor wont turn on
158,000 MILES • 4 CYL • FWD • MANUAL
GLEN C
  • 10 POSTS
just bought this car and the second day the air quits. The compressor is not engaging. I have pulled the relay and junp wired the two contacts that acctivate the compressor clutch. The clutch engages. The main 10 amp fuse is good.I have tried switching relays with others the same. The light comes on when you push the button on dash.
Apr 12, 2008 at 8:28 AM
GLEN C
  • 10 POSTS
got it done.............
Apr 13, 2008 at 5:03 AM
RCLARK1223
What did you do to fix your problem?
Thanks.
May 6, 2008 at 10:05 AM
