1993 Infiniti G20 Radiator overheats
GINGER THE ROSE
Engine Cooling problem
1993 Infiniti G20 Front Wheel Drive Manual
Hi - The radiator started bubbling over. Because it was an emergency, I took the car to a new/close by mechanic. They said the radiator was fine. However, they thought the engine fan might be malfunctioning. They wanted extra money to run the engine fan diagnostic. Does such a diagnostic exist or are they ripping me off? Can't you visually see the engine fan?
Jun 9, 2008 at 10:28 PM
KHLOW2008
  • 41,812 POSTS
Hi Ginger the Rose,
I must have lost touch because I have not heard of such a thing.
Run engine and switch on AC, if the fan runs they are ok.
Jun 15, 2008 at 12:46 AM
GINGER THE ROSE
Bless you and many thanks. Almost $200 later, they said it was 2 gaskets and a thermostat. I thought a hose busted. At least the charges didn't include the questionable "diagnostics." I think he was checking my knowledge base.
My rpm needle still wildly bounces when the engine is cold - but I did't tell them about it. It's an old, but very well maintained car. It's bound to have a few quirks.
The guy was rather condescending. When I dropped the car off and picked it up, he thought it was great sport to keep me waiting for no good reason. He wouldn't even acknowledge my presence. Even when another staffer tried to assist me, he insisted he would take care of me. I still waited and waited. I probably won't use them again. Besides the trust issue, I should not be poorly treated. I shouldhn't have to feel I need a gun toting man to make the mechanics behave. Were this not an emergency, I certainly wouldn't have used them. I won't recommend them either.
Many thanks again
Jun 15, 2008 at 2:40 AM
KHLOW2008
  • 41,812 POSTS
Hi Ginger the Rose,
Glad that you have solved your problem and sad that we again have another case on the bad side of professionalism.
Fluctuating idling during cold start normally are associated with the idling system and could have been solved without much difficulty.
Wonder why they did not try to sell you more which would be justified as it is a problem.
Jun 15, 2008 at 3:48 AM
GINGER THE ROSE
Bless you and thanks - I'll most likely take it and your suggestions to my trusted mechanic. I did run the a/c and engine - the fan worked fine. Most likely, I was right, it was a broken or loose hose. Antifreeze was splattered towards the engine and leaked on the ground. They indicated it bubbled up because the car overheated. My instinct tells me far too much antifreeze was on the ground for a bubble over. Oh well - you are correct - $200 isn't too bad.
Thanks again.
Jun 15, 2008 at 8:42 AM
