1993 Infiniti G20 A/C
190,000 MILES • 4 CYL • FWD • MANUAL
JOSER4444-951
i have a 93 infinity g20 that my a/c stopped cooling I check the fuses and they are fine I also check the copressor by taking a wire from the copressor o the + battery and the cluntch activates I also pressed on the valve and it appers to have freon because it spays out with pressure can you help.
Jul 4, 2008 at 12:22 AM
MERLIN2021
  • 17,250 POSTS
So what doesnt work? the fan inside the car? or the compressor?
Jul 4, 2008 at 12:44 AM
JOSER4444-951
IT BLOWS AIR BUT NOT COLD
Jul 4, 2008 at 12:52 AM
MERLIN2021
  • 17,250 POSTS
OK is the compressor running or not? It sounds like you are low on your charge, have the system checked for this.
Jul 4, 2008 at 2:08 AM
