1992 Infiniti G20 No spark on plugs
100,000 MILES • 4 CYL • FWD • AUTOMATIC
RICH21
Items that have been tested per the infinity manual...
1) Coil
2) Power transistor
3) wiring harness
a) checked from coil to power transistor
b) checked from power transistor to condensor resistor
c) checked from ECCS to power transistor
d) checked from ECCS to condensor resistor
4) The distributor was not checked but was swapped with the new engine and then swapped back from the old engine.
5) The condensor resistor measures 1.2 Ohms (should be 2.2 but I should get at least a weak spark) of resistance.
The system had blown a 10 amp fuse for the starter circuit.
The engine was replaced due to excessive mileage and blown head gasket (according to the used car dealer that sold it to my friend).
I follwed the Infinity manual and according to it I should have spark.
This is a friends car that he bought from a used car lot for nothing because it was not running and thier mechanics could not figure out the problem.
Is there any way to check the computer (besides self diagnostic) out of the car?
I am honestly at wits end.
Apr 16, 2008 at 12:57 PM
G20RUNNIN
I too have replaced an engine for my 92 G20, and like yourself, not getting any spark to the plug. Did you receive any answer that you can share?
Thanx......Rodney
Aug 20, 2008 at 9:33 AM
