I just need the location for the switch, I have looked all over for a diagram or answer and have found nothing.
Jun 21, 2016 at 8:26 AM
CARADIODOC
✓Experienced Mechanic
You car does not have an inertia switch they are only used on Fords. Please let us know if you need anything else to get the problem fixed.
Jun 21, 2016 at 8:31 AM
DCDC
MEMBER
1 POST
Trying to repair it, and dont know if its the fuel pump or if its the fuel shut off switch if it has one. If you could answer my question, and be so kind to show me a diagram or tell me where it would be located at would help me so much.
Jan 29, 2019 at 8:42 AM
(Merged)
It doesn't have a fuel cut off switch-not listed in Mit1-try directing battery power to the fuel pump connector and see what happens
