Engine will not stay running after a minor accident, Inertia switch?
90,000 MILES • 2.5L • 2WD • AUTOMATIC
BWEST25
  • 6 POSTS
My fiancé had a small accident a few days ago, he backed into another vehicle pulling out of a parking space. No damage to either vehicle so we went on. The next day I drove to work and on the highway my car kept losing power and then a few seconds later it would accelerate again, but never shut off. I got to work because I was only 5 minutes away at this point and parked my car. Five hours later I came out and my car started and then stalled out and then wouldn’t start again. It’s been sitting a few days and every day will start up but then stall out and then won’t start again at all. Could this be from the accident? My battery is fine and everything.
Mar 9, 2022 at 7:33 AM
WENDY W
  • 86 POSTS
Hello!
Have you been able to retrieve any error codes from the vehicle's computer? I've attached a couple of repair guides that might help you with the process:
https://www.2carpros.com/articles/engine-stalls
If you're able to retrieve any codes from the vehicle, let us know and we can try to help you further.
Thanks, Wendy W.
Mar 10, 2022 at 12:05 AM
BWEST25
  • 6 POSTS
My EPC light and check engine light are now on. My fiancé did scan for codes and I’m not sure of all of them at this time, but I do know a few coolant codes came up.
Mar 10, 2022 at 12:23 AM
BWEST25
  • 6 POSTS
And I believe a code regarding the ECU in it.
Mar 10, 2022 at 12:24 AM
WENDY W
  • 86 POSTS
You described some intermittent acceleration issues, and that would make sense given you're seeing the EPC (or Electronic Power Control) light on the dash. When that warning light is illuminated, it usually means there is a fault somewhere in the system that controls the position of the throttle valve. I've attached a more detailed description of this system below.
If you're able to share the exact codes that the vehicle is setting, we might be able to pinpoint it a little further for you.
Thanks, Wendy
Mar 10, 2022 at 1:11 AM
BWEST25
  • 6 POSTS
These are the codes.
Mar 10, 2022 at 1:56 AM
WENDY W
  • 86 POSTS
Hello!
Thank you so much for sending the codes you were able to retrieve.
It seems like only one is a stored code, P2181, and the rest are pending codes.
It might be a good idea to focus on the stored code first. I've attached the code description, possible causes, component locations, and repair procedures below. That particular code suggests there may be a fault with one of the engine coolant temperature sensors or with the thermostat. If there is a fault with one of these components, it could contribute to drivability issues.
Has the vehicle overheated recently, either before or after bumping into the other car?
Also, you may want to check the charging system to make sure it's functioning properly. This repair guide has some helpful tips for running that test:
Please let me know if there's any other information, I can help you with.
Thanks, Wendy W.
Mar 10, 2022 at 3:28 AM
BWEST25
  • 6 POSTS
The car never overheated; temperature was always normal on the gauge. Would the engine coolant sensor or the thermostat cause the car to not start? It won’t start at all now.
Mar 10, 2022 at 4:13 AM
WENDY W
  • 86 POSTS
It sounds like the engine will crank but not start. Is that correct? Or will it not even crank?
If the vehicle's computer is not receiving accurate information from the sensors, it can cause the air/fuel ratio to be incorrect, and result in a no-start condition or running poorly.
If the thermostat has stuck open, it could prevent the engine from coming up to operating temperature, and that also could cause it to run badly but not necessarily prevent the vehicle from running.
These articles explain this in more detail:
https://www.2carpros.com/articles/symptoms-of-a-bad-coolant-temperature-sensor
https://www.2carpros.com/articles/how-an-engine-thermostat-works
Since there were so many pending codes, it's possible that they are being caused by a faulty charging system. If the alternator output is too low, or if there is AC voltage present, it can trick the sensors and modules on the vehicle and cause all sorts of drivability issues and "false" codes.
Once you know the charging system is in good shape and you've recorded all the stored codes, you can try clearing them and see what comes back.
I hope this helps, Wendy W.
Mar 10, 2022 at 4:40 AM
BWEST25
  • 6 POSTS
The engine cranks and starts up the first time and then quickly shuts off. then any time you try to start in the next few hours it will still crank but will not start.
Mar 10, 2022 at 4:52 AM
WENDY W
  • 86 POSTS
Okay, thank you. Have you been able to check the fuses in the interior and engine compartment fuse blocks? I've attached diagrams showing their location, below.
Thanks, Wendy
Mar 10, 2022 at 5:12 AM
