Inertia switch location
20,000 MILES • 4WD • AUTOMATIC
SHELBIE KADIVA
  • 14 POSTS
I need a better picture of where the inertia switch is located please.maybe not a better picture but one more picture detailed.please
Apr 29, 2020 at 11:25 PM
Good morning,
There is no inertia switch for the fuel pump if that is what you are asking. That is for Fords only.
You have a relay. I attached a diagram of the fuel pump for you to view.
What is the issue with the truck?
Apr 30, 2020 at 12:16 AM
SHELBIE KADIVA
  • 14 POSTS
Are you ready for this? Okay, my boyfriend broke the key off in the ignition my dad took a pic to try to pick out the broken key and pulled the key forward a little bit which made the electric or the security alarm system go off and so he got that stuck in the ignition. So a friend of mine cut the starter and ignition wires connected them to make a toggle switch and a push button. then my dad went and put the wires back took the push button and toggle away and then got the key out we raised the key to a different key broken key so it's usable key at this point. It actually is turning the car over but not starting. the only thing I could think of is left to do is something to do with the fuel. I'm not a mechanic and I'm doing this pretty much on my own.
Apr 30, 2020 at 12:31 AM
Okay, is there a security light, theft light or a key signal on the dash?
https://www.2carpros.com/articles/how-to-reset-a-security-system
If there is, turn the key to on. See if the lights go out after about 10 seconds. This will tell me if it is a security issue or mechanical issue.
Can you hear the fuel pump run with the key on?
Apr 30, 2020 at 12:44 AM
SHELBIE KADIVA
  • 14 POSTS
Yes, there's a security light on until I put key in then to on position and yes I can hear pump for like ten seconds.
Apr 30, 2020 at 12:47 AM
Okay, does the light go out when you turn the key on? That is important. If it does not then it is a security issue.
Apr 30, 2020 at 12:53 AM
SHELBIE KADIVA
  • 14 POSTS
Yes, it goes out when I turn key on.
Apr 30, 2020 at 12:59 AM
Okay, you need to test for spark to the plugs to be sure there is spark being sent.
Also, you need to test for fuel pressure.
Apr 30, 2020 at 1:11 AM
