Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Citroen
C4
Exterior Light
Turn Signal
Not Working
Rear turn signal not working
2005 CITROEN C4
100,000 MILES
A NICHOL
MEMBER
1 POST
I have a rear indicator not working. I've put a new bulb in and cleaned the connection but still doesn't work.
Nov 4, 2020 at 6:28 PM
Experienced Mechanic
This vehicle isn't offered in the US, so I don't have specific wiring information. However, I will try to help.
If the bulb is good, either there is no power or no ground. If you use a test light, is there power to the light?
Nov 5, 2020 at 7:25 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
