Indicator wire loom
180,000 MILES • 2.0L • 6 CYL • 2WD • MANUAL
STEVEN187
Hello, my car had accident and 1 indicator wiring loom ripped out and possibly window washer wiring. I got the remains of the left indicator wiring it has about 80cm
of 6 wires with female plug still attached I know where there is a fto with all the parts and wiring. could I take indicator wiring and reconnect is it fixable or should I take to shop? i live in a country town electricians charge hundreds can't afford that at the moment. but keep to trying myself.
Aug 3, 2019 at 1:22 PM
Hi Steven,
If you have a vehicle that you can cut the connector off, then I would just go cut as much of the wiring that you need including the connector and then solder it onto your vehicle's harness.
Basically you want to cut the wiring on your vehicle where it is past the damage and then solder the replacement connector on in its place.
If you are not familiar with soldering then here is a video that will help show you how to do this. Clearly you will be doing this doing it outside the vehicle so just make sure you take the precautions he suggested.
Lastly, I would suggest taking and replacing both sides of a connector is one side is damaged. More than likely it damaged the other side which will cause it to not hold.
https://youtu.be/Zu3TYBs65FM
Aug 4, 2019 at 5:44 AM
