indicator light flashing when engine is on
45,000 MILES • 0.9L • 4 CYL • 2WD • MANUAL
JALALAHAS
My car Zen Estilo LXI-2010. when key on all indicator flashing continuously without pressing hazard switch. Flashing will not stop even for long drive. Please advise cause and any rectification to get it normal functioning.
Dec 27, 2020 at 6:02 PM
  • 110,248 POSTS
First, this vehicle isn't offered in the US, but I will try to help. As far as the idea that the flashers are all flashing once the ignition switch is turned on indicates there is a switch power source which has likely shorted to the flasher unit or the switch itself has shorted.
As a simple test, remove the signal flasher fuse and see if they stop. If they do, then we know the problem is related to the signal circuit. If they continue, then we have a short to a different circuit.
Here is a link that you may find helpful:
Let me know what you find
Dec 28, 2020 at 4:29 PM
