Turn signal indicator
72,000 MILES • 1.1L • MANUAL
AISHLING
When I put on my indicators to turn I turn my wheel to turn and my indicators turn off and my head lights go on.
Feb 6, 2017 at 3:05 AM
  • 31,937 POSTS
sounds as if there is a problem in the combination switch, there may be a wiring issue with something rubbing hard to say with out looking at the loom and doing a few continuity tests, if you can access the loom you can try a wiggle test, shake and pull on the loom, not with a lot of force as you do not want to damage further damage, if there is a short often this will show it up, otherwise it will be a auto electrician or the dealer as getting into the system any deeper will require the air bag to be removed and this is something for a professional to do.
Feb 7, 2017 at 8:29 PM
AISHLING
Thanks 4 getting bk 2 me i wouldn't hav a clue 2 do any of dat would it b expensive 2 get it sorted
Feb 8, 2017 at 6:27 AM
  • 31,937 POSTS
Just can't say with out actually doing some hands on diagnosis ring around and se if you can get a quote to have it looked at you may be up for an hours labour to find the problem of it's not to deep on the electrics
Feb 8, 2017 at 9:05 AM
AISHLING
I'm thanks 4 getting bk 2 me
Feb 8, 2017 at 5:42 PM
  • 55,694 POSTS
Please let us know what you find so it will help others.
Best, Ken
Feb 13, 2017 at 1:32 AM
