Indicated low oil pressure at idle when hot.
164,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
OLDHOTRODDER
Oil pressure gauge drops to 5# or less at idle and chime starts when hot. Using scanner for readings. NO internal engine noise ( bearings or lifters ) at idle. Engine is quiet. Replaced oil pressure switch w/ o.e.service switch. Replaced oil pick up tube "O" ring. Pick up screen clean. Replaced oil pump w/ o.e. service pump. New oil filter and 10/30 oil. Have pressure at cold start ( no engine noise on cold crank). Oil warms up, pressure drops, chime sounds at idle. No prob. off idle. Gauge seems slow to respond. Is this oil press. and chime possibly an electrical issue with the cluster or ECU? I'm a retired ASE Master. Specialty in foreign vehicles, GM was not my expertize.
Jul 23, 2014 at 4:47 AM
HMAC300
  • 48,601 POSTS
check the pressure with a manual gauge first to see if it's electrical, then put a decent oil filter on it like Purolator, wix, napa, or bosch. a/c is ok too. if it's a cheap filter like a fram will cause issues like this.
Jul 23, 2014 at 5:24 AM
OLDHOTRODDER
Sorry for the delay. Mechanical pressure is 5# at idle, hot. Mobil1 filter. Still 10/30 Castrol hi mileage oil. Sense we've gone this far, we're going to roll a set of mains & rods on the crank. Bottom end will be secured and apparently it's not electrical. At 164,000 mi. I'm considering straight weight oil. Will find out after bearings in.
Jul 28, 2014 at 4:10 AM
HMAC300
  • 48,601 POSTS
if you are going that far, take the pump off and check thereleif valve for sticking it may have some junk in it causing it to stick when hot.
Jul 28, 2014 at 4:59 AM
OLDHOTRODDER
New Pump. normal crud in pan. No crud in bottom of pan. Nothing loose to address and we cleaned inside of pan. Internals looked clean. we'll find out after bearings. we'll find out after bearings. Still thinking straight weight oil. only happens when oil gets warm. Crud should have given us normal pressure for a while.(?)
Jul 28, 2014 at 6:56 AM
HMAC300
  • 48,601 POSTS
re won't be any benefit at all with straight weight oil I fyou put new bearings in you can still use the 5 or 10w 30. You shold not use the high mileage oil in your vehicle though If your pressure is ok then use synthetic if you like much better oil but expect some usage at first
Jul 28, 2014 at 8:33 AM
OLDHOTRODDER
New bearings worked. Pressure up to about 10# at hot idle. no chime. Dumped high mileage oil and put in our house oil, Castrol 10/30. Drove it about 150 mi. and every thing seems normal. THANKS!! For the help.
Aug 5, 2014 at 5:11 AM
