Is this normal or is there another issue I should check for?
Inconsistent Idling after Battery Replacement?
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the battery state of charge, charging-system operation and loaded voltage drops across the battery connections, cables and grounds checked. A terminal can feel tight while the electrical path still needs testing. Compare charging measurements with the vehicle's operating conditions and service requirements. The reported readings do not by themselves separate an alternator fault from a cable or connection problem; the later no-start should not be dismissed as ordinary idle relearning.
Guidance references and applicability
Source discussion: question 1712798 https://2carpros.com/questions/inconsistent-idling-after-battery-replacement--1712798 Supports the reported history and outcome only. Follow-up guidance is editorial synthesis; unverified specifications and diagnoses are not adopted. Fluke: Diagnosing voltage drops https://www.fluke.com/en/learn/blog/automotive/electrical-automotive-troubleshooting Supports loaded feed and ground testing. Use matching wiring and vehicle-specific test limits.
https://www.2carpros.com/articles/engine-stalls-idles-too-high-low-after-dead-or-replaced-battery/
Let me know how it goes
Even with a brand new battery, my car drive fine this morning then while idling in a parking lot, my warning lights flickered and flashed on again and after turning the car off, my car didn't start again.
Does this point more towards an alternator issue; or what could be causing my battery to completely drain even after a brand new one was put in last night?
https://www.2carpros.com/articles/everything-goes-dead-when-engine-is-cranked/
Let me know how it goes.
It drove fine for a few hours this morning before dying down and not starting back up parked in a parking lot.
This is why I'm guessing it might be an alternator issue, as the battery is brand new and still won't start after a few hours of driving.
Any other advice or ideas?
https://www.2carpros.com/articles/how-to-check-a-car-alternator/
Please go over this guide and get back to me.
We jumped the car and got it running; battery tested around 12.2v before cranking and after the jump start and keeping RPMs around 1500 in park, only slowly climbed to around 13v.
Turned on lights and air conditioning for a load test and my dashboard warning lights started to come on again; so I'm definitely feeling at this point it's the alternator between the voltage only reading 13 after a jump start and revving the engine, and the warning lights coming on as soon as I click on the radio, air, and lights.
Discussion summary
After battery replacement, the owner reported uneven idle, followed by flickering warning lights and a no-start. The owner reported about 12.2 volts before starting and approximately 13 volts after a jump-start, with warning lights returning under electrical load. An aftermarket positive-terminal end and the charging system were both discussed.
Reported outcome: No confirmed alternator or terminal repair was reported.
No charging-current, voltage-drop or complete battery-test results were supplied. Corrosion under the terminal clamp was suggested, not observed.
