Inability to start the car after no use for 5-6 or more days
150,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
ALAN STEGER
I rarely use the car listed above vehicle (4 door), so I leave it parked for several days at a time before attempting to. I live in San Francisco where the temperatures in the last month or so have ranged from the 60's during the day to low 40's at night.
Beginning about 3-4 weeks ago, I found I was unable to start the car after it had been parked for5-6 days. I would then call AAA for a jump start and it would start up relatively easily. I'd then let it run for 20-30 minutes and, possibly, do some errands where I'd be able to turn off the engine in between doing 2-4 errand stops and restart the car with no difficulty.
I found I could always leave it 3 or 4 days without problems restarting but when it got to 5 or 6, I'd need a jump start. I had the battery, starter and voltage regulator checked by the company that sold me the battery. Their 'diagnosis' recommended 2 problems:
1)Replacing valve cover gasket and tube seals since they said oil was getting on the spark plugs (which they also wanted to replace). When I asked how the car could be easily jump-started without all the oil on the spark plugs being cleaned off, they had no answer. I am aware of the gasket problem but that it could cause the not starting up after 5-6 days of not use made no sense. One Toyota dealer agreed with me.
2)They said the Idle Air Control Valve was bad and needed replacement. As far as I'm concerned, I have never had problems with the car stalling and the car idles quietly at a low level. The same dealer I had spoken indirectly to (via a third party) believed that Idle Air Control Valve could be causing problems starting.
What wasn't answered is how could a jump-start cause it to start and then run smoothly with a 'bad' (possible dirty) Air Control Valve?
Your comments on the website 2 carpros.com were that the air/fuel mixture could be thrown off so much as to prevent it from starting, though it was rare. Once again, why did a jump start cause it to start and run normally?
I don't know how the dealer who actually tested the car made his determinations, possibly by codes that showed up. I didn't trust his determination or thoroughness.
As a used car I seldom use for any more than local trips, I am reluctant to get a Toyota's dealer's diagnostic (about $225.00) and have them recommend repairs that won't fix my starting problem. I'm not convinced that the proper cause has yet been identified. I also will need to have the car smog-tested within a month in order to re-register it. Is there any mechanic you could recommend in the SF area?
Any advice would be appreciated.
Alan Steger
Jan 25, 2022 at 1:30 PM
SQM
  • 6,383 POSTS
Let's take a look at the no start issue.
From what you are describing, it sounds like your vehicle has an excessive amount of parasitic draw (current drain), which is draining the battery after a few days.
All electrical circuits will have some amount of draw, but it can become excessive due to any number of faults within any of the electrical components. It could be as simple as a glove box light staying on or could be a shorted switch.
To figure out what is causing the draw you will need a multimeter and check the current drain on the battery with the vehicle off. Then remove fuses and check for the draw again. This will tell you which circuit is the problem by reducing the amount of draw on the battery.
Take a look at this video, it explains it nicely on what to do:
https://youtu.be/z5F7WpgjaRs
https://www.2carpros.com/articles/car-battery-dead-overnight
As for the oil leak, I don't see how that can impact on the battery being drained.
Jan 26, 2022 at 1:47 AM
