In tank diesel pump not working. Can I change the in tank diesel pump with an outside inline electric diesel pump?
Feb 21, 2019 at 4:24 AM
✓Experienced Mechanic
You cannot install an aftermarket pump outside the tank. Here are questions and diagrams on how to change out the fuel pump with a video showing how to drain the tank before you begin:
Images (Click to enlarge)
Feb 22, 2019 at 5:07 AM
CAPETOWN
MEMBER
I need to remove the diesel tank to replace the defective in tank diesel pump. Must I remove the prop-shaft also because this car is a 4wd? Apart from the fuel pump relay is there a fuse also?
Feb 25, 2019 at 4:31 AM
(Merged)
Yes you will need to remove the drive shaft before you can get the tank out. Here are guides to help you get started:
