Where did you find the hex bits for a 3/8 drive impact screwdriver? It's used to remove the screws that secure the brake rotors.
Aug 19, 2019 at 9:08 AM
✓Experienced Mechanic
Most any parts store has them. Worst case I would use a 3/8 socket that is small enough that the hex bit fits into it.
I agree, I use these as well and you can make them work if you can't find the specific bit. Let me know if you still have issues and I can help further. Thanks
