Transponder key not programming
193,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
HEATH HEISTAND
I can program my transponder key with the CK-100 but when I go and take out the key for approximately 2 minutes the key won’t start it. i redo the whole process again program key with ck-100 the car will start but shuts off car for approximately 2 minutes then it will go back to having chain of immo key.
Nov 27, 2020 at 3:38 AM
4DRTOM
  • 467 POSTS
I would change the battery in your transponder, it has most likely forgetting the programming that your doing. Make sure the contacts are nice and clean as well this will probably take care of your problem but if it doesn't let us know and we can dig into the issue more but start there and rule that out first.
Tom
Thanks for using 2CarPros.
We're hear to help with all things big and small.
Nov 27, 2020 at 3:46 AM
