I had to unplug some of the harnesses in the dash area to pull dash out. When in reinstalled the dash and plugged everything back in when I tried to start the car it clicked everything on turned over one time and then completely shut everything down. No lights no power, no crank. When I hooked up a remote starter button the engine would crank but no fire. Ignition relay is good solenoid still working because it turned over, all other fuses still good. only problem is I don't have main key just spare. Trying not to spend $200.00 on new ignition if possible. Any suggestions appreciated.
May 6, 2021 at 2:17 PM
