Car not starting
43,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
COLLIE FLOWERS
We have had problems with car not starting. Had breakdown out who said sticking immobilizer, battery checked he said it was at 12 which was okay. Breakdown started it - booked it in garage - now car not starting. Could it be battery please?
Jan 5, 2020 at 12:38 AM
TOUGHDIVER
  • 226 POSTS
You can tell if your battery is faulty by having it tested properly, If your Vehicle won't crank you have a problem in the starting circuit; I have attached some links below for to follow for proper battery testing and charging system check, This will let you know if your battery needs replace or if it is something else. Please let us know if this information was help and if you need more help,
Thank you
Joe T.
https://www.2carpros.com/articles/symptoms-of-a-bad-car-battery
https://www.2carpros.com/articles/how-to-replace-a-car-battery
https://www.2carpros.com/articles/how-a-car-electrical-system-works
Jan 5, 2020 at 11:50 AM
