severed the antenna wire on the Immobilizer
170,009 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
DRAGE1988
I severed the antenna wire on my immobilizer to my vehicle, I'm wondering if I can rewire the antenna wire or if I need a new immobilizer?
Jan 1, 2022 at 10:23 PM
SQM
  • 6,383 POSTS
The antenna wires are typically the gray and brown wire for these immobilizers.
Where did the wire break? Unless there is damage to where the wires go in you should be able to reattach by soldering.
Here is a helpful video on how to solder:
https://youtu.be/4TjSYfLTHfg
I have attached the wiring schematics for the immobilizer below.
Jan 2, 2022 at 3:24 AM
  • 110,248 POSTS
I would be happy to do that for you, but I have to ask a favor. I need you to copy and paste your question to a new post. We try to keep the vehicle makes and needs specific to one topic, so they are more helpful to others. I hope you understand.
Here is the link to start a new post:
Again, I hope you understand.
Thanks,
Apr 10, 2022 at 12:51 PM
