Can it be repaired? Nissan Almera Tino 2,2 DCI 112 hP.
Oct 3, 2024 at 6:41 PM
✓Experienced Mechanic
Anything can be repaired; what problem are you having? Security light flashing? If so, I would disconnect the battery overnight and then reconnect it. This should reset the system. If not, you can try a hard reboot. Here is how:
Thanks, I think I'll do it!
The question of whether the computer is a Bosch! Because my mechanic claims that nothing can be done with the immobilizer and there is no way to turn off the red key on the dashboard!?
Oct 4, 2024 at 8:06 PM
That is incorrect. There is always a way to fix the car, that's why I like them. We should run a CAN scan. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
