the immobilizer was active and the car shut down?
98,000 MILES • 2.5L • 5 CYL • 2WD • AUTOMATIC
JAMESHYNES
  • 13 POSTS
My instrument cluster was severely damaged (burned) but still worked. I decided to get a used one and swap it. I swapped it and as soon as I started the car, I got a notice the immobilizer was active, and the car shut down. Fortunately, I can (and did) put the old one back in so I can drive it. Any advice on how to get the replacement cluster to work? Or maybe how to disable the immobilizer?
Aug 28, 2024 at 12:59 AM
  • 55,658 POSTS
The instrument cluster must be programed to the car, here is what is said:
Instrument Cluster (K), Replacing
Work procedure "replace Instrument Cluster" contains the following scope of work:
If a new Instrument Cluster is installed, the Instrument Cluster Control Module (J285) must be set for the various equipment characteristics, coding and service data.
To adapt the integrated Anti-Theft, Immobilize Control Module (J362) with the Engine Control Module (J623) , it is necessary to save the data from the Engine Control Module (J623) in the new replacement Instrument Cluster.
Also, all ignition keys must be adapted after the installation of a new Instrument Cluster.
The procedure "replace the Instrument Cluster" can only be performed in "Guided Fault Finding" using the Vehicle Diagnostic Tester.
Procedure
- Connect the Vehicle Diagnostic Tester.
- Select Guided Fault Finding.
- Use the GO TO button to select the "function/component selection" and the following menu options one after the other:
Body
Electrical Equipment
01 - On Board Diagnostic (OBD) capable systems
17 - Instrument cluster
Instrument cluster functions
Instrument Cluster, Removal and Installation
, So much for plug and play huh? home computers have been doing this for years, but car manufacturers make it a pain, so you bring your car to them.
Aug 28, 2024 at 1:58 AM
