I'm having trouble with my Lexus again
19,000 MILES • V8 • 4WD • AUTOMATIC
BEASTBOY
  • 5 POSTS
So yesterday I took my Lexus for the smog Check it passed everything except one thing they said the check engine light doesn't turn on the dashboard when I start my car and I want to find out how to fix that so my car can pass the smog check again
Dec 31, 2013 at 6:07 AM
HMAC300
  • 48,601 POSTS
check to see if bulb is missing or burnt out
Dec 31, 2013 at 7:19 AM
BEASTBOY
  • 5 POSTS
Really I'll have to check that if the light bulb is missing or is burnt because the mechanic said it had something to do with the motor and some pipes
Jan 1, 2014 at 9:45 AM
HMAC300
  • 48,601 POSTS
does it light up at all? if it has something to do with the motor then there was a code if we don't know the code how can we tell you what to check? If it passed then you only need to get the bulb working the first thing is to see if it's burnt out or missing.
Jan 1, 2014 at 10:04 PM
