While driving the engine shuts off
244,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
RWEINELT1
Truck stops running while driving. I replaced ignition rotor. It starts and runs fine for about a week one hundred to two hundred miles a week then quits running again?
May 6, 2018 at 11:10 PM
CJ MEDEVAC
  • 11,000 POSTS
Works again for a week with a new rotor button?
With the distributor cap off, using your fingers, is there any circular wobble on the shaft the button sits on? (Not CW or CCW rotational play) (Understand?)
Can you see any unusual wear on the button while comparing it with a new one?
The Medic
Sep 3, 2020 at 6:01 AM
RWEINELT1
Replaced distributor and coil last year, problem still continued. It has accelerated since we rebuilt TBI and pressure regulator.
  • 55,746 POSTS
When the engine stalls do you hear the pump in the tank still running? Also, lets check for spark it see if it is ignition related.
This guide can help as well.
https://www.2carpros.com/articles/engine-stalls
Cheers, Ken
